6.2 firing problem
Discussion in '1982-Present GM Diesel' started by mike race, Jun 10, 2001.
  1. mike race
    mike race 1/2 ton status
    115
    Orlando, Fl
    Just swapped a 6.2 with a 6.2. Fires with diesel soaked rag on breather. won't other than that. pump worked pryor to swap. any ideas? any tricks?
    fix'n finally
  2. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Air in the system? Fuel lines hooked up (got to ask)? Is there fuel coming out of the injectors? Is the shut off connector hooked up (big pink wire on top of injector pump)?
    Hope something helps.
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
