6.2 Flywheel?
Discussion in '1982-Present GM Diesel' started by mstockton, Apr 30, 2007.
  1. mstockton
    mstockton Registered Member
    Apr 20, 2007
    99
    California
    Hi there,
    I've got a quick question hopefully someone can answer for me here.
    Got a 6.2 in an 82 K5, swapping in a sm465, talked to a vender about a clutch and flywheel from LUK. Says that the C code engines flywheel's were discontinued, but they have J code for 188. I'm just wondering what the difference was, I didn't realize flywheels were different for the two models. I want to use a 12" clutch, since I've hearde the hydro bellhousings can use them, so was it clutch diameter, therefore bolt holes in the C series flywheels that were different or what? Just want to make sure the flywheel I get will bolt up to my C code cranshaft.
    Thanks much,
    Martin
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i *think* the only difference between a c and a j was the intake...
  3. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    I have a flywheel out of a 6.2 86k30. If there are numbers you need off it let me know where to find em. Yours 4 $50 + ship.
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    LFW201 is what I'm pretty sure you'll need. That's what I got for mine and nobody asked me if it was a C or J code so I'm almost certain there is no difference. Watch it though, my flywheel did not come with bolts, nor did my pressure plate so if you don't currently have any then you'll need to find some.
  5. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    IIRC there is a difference in # of bolts but I can't say if that is engine codes, years, or what.
    I'll see if I can find mine:o (parts, parts, parts everywhere!) and take down some #s and such
  6. mstockton
    Apr 20, 2007
    99
    California
    I just did a search for that part number, and I think that is the one I want, it lists it as the 85-93 6.2 flywheel, which is for hydro clutch like I want, so I believe I will order this part number.
