6.2 flywheel
Discussion in '1982-Present GM Diesel' started by jeffro, Sep 15, 2002.
  1. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Is the flywheel on an 82 6.2 externally balanced and, if so, will one for a sb400 fit?
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I know the diesel uses a different starter and ring gear with coarser teeth. I seem to remember the 6.2L flywheel being unique back when I was in auto-wrecking.
    My 2 cents.
  3. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    6.2 diesels are 139 tooth, not the same as a sbc
  4. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    lets see sbc= 150 # compression
    a 6.2 = 380 # minimum or more i dont think a sbc starter would even turn the motor over
    i have the stuff 4 sale if needed
  5. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Since this is Jeffro's post, he gets first dibs on the Flywheel, but if he doesn't want it, I would like to know what you want for the 6.2L Flywheel! Thanks!
