6.2 guys ... mpg?
Discussion in 'The Garage' started by jackedjimmy350, Aug 31, 2005.
  1. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    what are you getting for mpg?
    i have a chance to pick up an 84 m1008 at a reasonable price, and was wondering if it might help cure my current 10 mpg problem.
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    I get 16.5 mpg with my 6.2 on the highway. I'm running the SM 465, NP 205, and the diff's from a M1008 (4.56's, rear detroit) and 39.5" TSL's.
    The more you can lower the cruise rpm's of a 6.2 the better mileage you'll get. Mine cruises at ~2600 rpm. Max efficiency for the 6.2 is about 1800 rpm where you can commonly see 23-24 mpg.
    Rene
  3. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I have an 86 K30 with a 6.2. Here's the specs: 7200lbs, SM465 transmission, 205 transfer case, 4.10 gears, 35x12.5r17 BFG AT, 4 inch Skyjacker lift. I get a consistent 15mpg average. My engine is pretty tired, it burns oil and smokes a lot at startup. I also run a lot of highway miles at 70-75mph. I understand that the lower you can keep the rpms on the diesel, the better mileage you can expect. I have seen as high as 18mpg and as low as 10mpg. The 10mpg was only during a very cold winter in Alaska when I was idling the truck for more than an hour total each day.
  4. jwglover
    jwglover Registered Member
    Jun 2, 2003
    88
    I get 20 mpg real easy, 88 crewcab 4x4, 6.2 turbo, 5spd , 33 in tires, 3.73 gears,
    but it doesnt hardly have the power to pull the hat off your head
    pulling 7 ?? what a turd . and dont be in a hurry to get there !
  5. Kiwi John
    Kiwi John 1/2 ton status
    Jun 24, 2005
    249
    West Sussex, England, U.K.
    Cant vouch for the accuracy of the aftermarket tacho but mine cruises around the 15-1800 rpm on 33's and gets low to mid 20's mpg. Mainly cos road speed is lower here due to congestion. It doesn't get into the overdrive as often as i'd like.
  6. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    i get 18mpg with my 89 burb 6.2 :waytogo: not bad for a led sled.
    and if u get 20mpg with an 88 crew 6.2 turbo maybe I need to invest on a crew dual 6.2 one of thesedays :D
  7. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Had a 1983 suburban 1/2ton, 4X4, 6.2/TH700R4, 3.42 gears, 235/75R15 would get 20-21 highway.
    1988 K30 crewcab 6.2/TH400/4.10s on 235/85R16s would get ~16mpg, with the gear vendors it bumped highway mpg around 18mpg. Towing a 35' jayco 5ver was 10mpg.
    2000 K3500 crewcab SRW 6.5TD/4L80E/4.10s running 245/75s gets around 16 on the highway, keep it 65 and under will get 17.
    1998 Dodge/cummins/auto running 3.54s and 285/75s is getting around 20 on straight highway pushing 75mph :D .
  8. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Same here...
    My 82 K20 with a 6.2 ,TH400,gears ??,245/75/16 tires,--gets about 15-22 mpg..lately its been sitting due to fuel prices,but I suspect the milage would be the greatest in warm weather..it used less fuel than my 400 small block did plowing ,I can say that for a fact!...like half as much!..Its no drag racer,but it has very good low end torque,and I dont care if wont take off like a jet...I'm happy with it.. :crazy:
  9. 6.2LTrailblazer84
    6.2LTrailblazer84 1/2 ton status
    Jul 4, 2005
    201
    san diego
    So if you had a hybrid electric/diesel combo.. would this be about your max efficiency I wonder?
  10. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    17-19 with 6.2 sm465 and 33's. I need to get this thing running :D
  11. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    20-24 86 Burb 6.2 700R4 3.08
