6.2 injection pump adjustment-fuel volume
Discussion in '1982-Present GM Diesel' started by elacruze, Nov 7, 2004.
  1. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    I know how to turn up the volume on the pump-but how do I know where the factory had it, how much I can turn it up, how I'll know when I've gone too far, and what will happen if I do?
    I've a Snap-On 480 timing meter in the mail, so I'll be able to adjust the timing correctly and adjust for extra fuel.
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Turn it until you get your EGTs to a comfortable level for you and the condition of your engine. If you dont have a pyrometer, you shouldn't be turning it up IMO.
  3. elacruze
    Dec 23, 2003
    121
    SE Michigan
    So there are no mechanical issues, just EGT's? I can't damage the pump?
  4. BlueBlazer
    Feb 15, 2001
    1,940
    Nope, in fact some tractor pullers used and probably still do completely remove the leaf springs in the pump which limits plunger movement. The preload on the leaf springs is what youre adjusting with the screw. The more preload, the farther out the plungers can go, the more fuel that can be injected.
  5. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    if you dont have a pryometer(i dont) how far could you crank it up with it being ok. I was told that if your truck doesnt blow much black smoke when you floor it, it is running lean and needs more fuel.
  6. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,038
    1,105
    Dallas
    For a ballpark guess without gauges, start with 1/8th - 1/6th of a turn. I recommend being conservative in your adjustments until a gauge finds its way into your plans.
  7. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    I sure wasnt /forums/images/graemlins/crazy.gif Then again i wasnt to worried about melting the motor down either when i did it. I really should get a pyro, but im afraid of what i will see /forums/images/graemlins/ignore.gif
