6.2 injector pressure?
Discussion in '1982-Present GM Diesel' started by 4by4bygod, Jan 22, 2007.
  1. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Hi All!
    Does anyone know the injector pressure for the older 6.2 engines?
    From what I've dug up, the newer common rail systems see around 20,000 PSI, and I was wondering about the older engines..
    Tom
  2. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,193
    356
    Ridgecrest, CA
    I'm not exactly sure, but a coworker of mine who is a diesel mechanic said on the Detroits they usually pop off at about 1000 psi and close back up at about 750 psi. The 6.2 is a Detroit Diesel.
  3. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    Detroits use a different injector than a 6.2, way different, so thats kind of an apples to oranges thing. I remember reading somewhere its about 2500psi on a pop test stand. That pressure is different on a running engine as cylinder pressures rise so does resistance to injector pressure so it goes up as well. I was told by a Mack tech that that under full boost and full load that injector pressure might get as high (on that truck) 22,000 psi even though the injectors poptested at 2750 psi. Rereading this I hope it makes sense....
    George
    I have the flu and am willing to share.....
  4. 4by4bygod
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    thank you for the info.. I'm doing some research on injector coking, and looking at the relation to injector pressures and various fuel blends.. it helps to know what is going on with the various setups..
    Tom
  5. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    1700 on 6.2
    1900 on 6.5
    2200 on 6.5 turbo.
  6. 4by4bygod
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Thanks again!
