6.2 problems
Discussion in '1982-Present GM Diesel' started by 1967k10, Mar 23, 2006.
  1. 1967k10
    1967k10 1/2 ton status
    Nov 21, 2005
    1,728
    Nebraska looking for D60's
    We have an 86' K30 dually work truck with a 6.2 and it's giving us trouble. At random it will loose all power and won't move.Some of the time you can shift it to neutral and it will rev up other times it won't rev even neutral.Most times it will rev in neutral. It's got a new fuel filter and the air filter was just cleaned.
  2. snoman87
    snoman87 Registered Member
    Aug 25, 2004
    88
    Edmonton, Canada
    Have you checked for air leaks and/or replaced the fuel filter
  3. maynardogle
    maynardogle 1/2 ton status
    Mar 7, 2005
    159
    Orange County, CA
    Sounds like injector pump is going away...
  4. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Has this problem been progressively getting worse? If so, it sounds like the injector pump to me. These are the same symptoms that my '84 GMC pickup had when the injector pump went.
    Just my $.02
  5. 1967k10
    Nov 21, 2005
    1,728
    Seems to be getting worse.I think you are right about the injector pump.I checked with a mechanic friend of mine and that's what he said.Now we need a new pump.
  6. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    You can get a reputable shop to rebuild yours for around $300.
  7. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    hmmmm...
    Seems to me I read a post here a while ago about injector pumps having a check valve in them that screws up or something,and contacts under the cover that oxidize..:confused: cant remember!..maybe search those posts?..
    It might be something simple like the fuel cut off solenoid on the pump losing power due to faulty wires,ignition switch,etc.. or the solenoid itself crapping out..that would be an easy fix..:crazy:
  8. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Just throwing this out there.... When I was young, I worked at VW Parts Department. I had a garage call up and check prices for a VW diesel injection pump. I gave him the price, but I also mentioned we NEVER sell pumps - Bosch pumps outlive the cars. I happened to mention this call to my boss and he knew what the problem was right away. Called the guy back and told him to fish around in the tank for the fuel pick-up. Check to see if the screen was still on the line and if it was to throw it away. Guess there was a service bulliten on this way back.
    Guy calls back about a half hour later excited. The screen was covered in diesel pariffin (wax goo) and this was in the SUMMER! Spent hours trying to figure this out and was taking a beating by the customer :haha:
    Anyway, it's a PITA to drop the tank just to look, but if there's garbage on your sock it would be acting just like you describe.:thinking:
