6.2 Rebuild Cost
Discussion in '1982-Present GM Diesel' started by Drey, Oct 17, 2004.
  1. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    If any of you guys have rebuilt a 6.2 how much does it cost? New pistons, boring out(to 6.5 if anyone has done it?)new crank possibly and new gaskets. My motor is very screwed up, Ill leave it at the fact my harmonic balancer is moving enough to move the hell out of my fan belts when it is running.
    I have no experience rebuilding a motor myself, but between, me, my dad, and my friend andrew who is a tractor mechanic I think we could get it done. Although I am still considering taking it to a shop, because my dad isnt to thrilled about the idea of tieing up the shop for awhile...
  2. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,040
    1,108
    Dallas
    Let's make some assumptions:
    You do all the assembly yourself, your crank checks out and so does your cam, you replace lifters, pistons, all gaskets, all bearings, and you are just going back to stock specs on fuel delivery.
    Expect to spend about $2500. That includes machining, and the cost of getting the IP and injectors rebuilt. Add a turbo to the project list, and the price goes up quickly.
    Unless the last three digits on you block are 599, then you can't bore to a 6.5L. Stock bore is 3.98, and to get to the required 4.05 bore of a 6.5, you would have some serious problems with cylinder wall thickness. .030 over will get you up to 386 cubes, and that's more than enough to clean up most bores.
  3. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    /forums/images/graemlins/eek.gif, if it's making really bad knocking sounds pull the pan first. If the crank is broke you can pretty much write off the block, it'll be cracked--atleast the ones I've come across were.
  4. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    well it knocks to beat hell, always has. Should the motor be able to run with a busted crank. Because I can still get it to start and drive down the road.
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Where are these numbers at on the block?
  6. AgDieseler
    Jan 25, 2001
    1,040
    1,108
    Dallas
    Two spots:
    On the back of the engine on what would physically be facing the flywheel, and on the back of the driver side bank of cylinders.
  7. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    I have seen them run with the crank broke between #1&#2 main journal. That is when the harmonic balancer flops around.
  8. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    Ditto. My '84 ran with a broken crank. Hellacious knock. Had bad harm balancer. Block was toast also. Most 599 blocks are 6.5s but not all.
