6.2 to 6.5 swap
Discussion in '1982-Present GM Diesel' started by klebmorris, Oct 12, 2002.
  1. klebmorris
    klebmorris Registered Member
    Sep 18, 2002
    8
    South Carolina, USA
    Has anyone ever performed a swap with a 6.5 turbo for their old 6.2? Does the 6.5 just bolt in? What's to be done about the possibility of the 6.5 having newer electronics?
  2. DieselBurb
    DieselBurb 1/2 ton status
    Oct 8, 2002
    201
    Mt. Vernon, Missouri
    The swap should be a direct bolt in. If you are wanting to keep it mechanical instead of going with the computer controlled, I believe all you have to do is use a mechanical (or aftermarket electric) fuel pump and the mechanical controlled injector pump. /forums/images/graemlins/burb.gif
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I think there is an issue with the 6.5L exhaust manifolds in the older frames. Maybe someone else has more/better info...
  4. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I remember hearing something about the turbo not clearing the ac stuff. Hope it helps Mike
  5. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    Maybe try looking for a transplant out of a diesel van, much more likely to clear the A/C stuff... /forums/images/graemlins/wink.gif
    Jon /forums/images/graemlins/burb.gif
