6.2 Torsional damper/3 groove pulley wanted...
Discussion in 'Parts & Trucks Wanted' started by uglytruk, May 15, 2006.
  1. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    Need mid '85 up crank pulley. Part # 15592128. GM calls it a torsional damper. Mine has 3 belt grooves. Excellent used only as rubber deteriorates. Attaches w/4 bolts. No puller requ'd. Shipped to 12901, Plattsburgh, NY
  2. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    Are you looking for the pulley or the balancer because I have both off of 1984 6.2 that broke the block.
    bigred81
  3. uglytruk
    Oct 24, 2004
    1,329
    Pulley. 3 belt grooves. The mid '85 and newer use a rubber cushioned pulley. I wonder if the harmonic also deteriorates equally? Check the rubber carefully... Shipped to 12901, Plattsburgh, NY
