6.2 vs 6.5 ?'s (edited)
Discussion in 'The Garage' started by DieselBurb, Feb 16, 2004.
  1. DieselBurb
    DieselBurb 1/2 ton status
    Oct 8, 2002
    201
    Mt. Vernon, Missouri
    6.2 vs 6.5 ?\'s (edited)
    Anyone know the HP/torque differences in general?
  2. DieselBurb
    Oct 8, 2002
    201
    Re: 6.2 vs 6.5 ?\'s (edited)
    ttt
  3. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,038
    1,106
    Dallas
    It depends on the year of the engine and the truck it came in.
    Early 6.2L non-turbo with DB2-4126 to DB2-4878: light duty emissions C code engines ~ 160 hp and 280 lb-ft; heavy duty emission J code engines ~ 180 hp and 285 lb-ft. Add a Banks system with a Garrett T04B turbo, and power goes to about 205 hp and 390 lb-ft.
    1993 3/4 & 1 ton 6.5TD with DB2-4911 ~ 190 hp and 380 lb-ft. You can tune this up to about 230 hp and 450 lb-ft.
    1994-1996 3/4 & 1 ton 6.5TD with DS4 pumps were just about the same.
    Late 1996 to 1998 3/4 & 1 ton with DS4-5288 pumps were 205 hp and 450 lb-ft.
    1999-present Vans and Hummers with DS4-5521 pumps were about the same, but with blocks cast by IH, 19.5:1 compression, and bigger turbo.
    Aside from making sure the engine is in sound condition, the basic formula for any good running mechanical 6.2/6.5 is a turbo (TE06H, T04B, GM8, etc.), DB2-4911, and timed based on the fuel and boost. If you're going for 14+ psi of regular boost, an intercooler is must.
  4. DieselBurb
    Oct 8, 2002
    201
    Thanks for the info. How about number for a 94 6.5 NA?
  5. AgDieseler
    Jan 25, 2001
    1,038
    1,106
    Dallas
    A 94 should still have the DS4 pump, but it will be tuned down from the turbo specs. I really don't know for sure, but my guess would be around 180 hp and 300 lb-ft - tops.
  6. DieselBurb
    Oct 8, 2002
    201
    I just checked your webpage...Duuuude, you have a sweeet /forums/images/graemlins/burb.gif.
    ....it's my thread, I can highjack it if I want to...
