6.2 wiring harness
Discussion in 'The Garage' started by bear76, Feb 28, 2007.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    As soon as the weather breaks I will be replacing my wiring harness. I am looking at the painless kit as well a others. My question is, is the 350 harness the same as the 6.2 harness. Are the guages the same (oil,temp...)? And, can I use the power wire for the HEI(?) for the IP?
    Thanks.
  2. twodollars
    twodollars Registered Member
    Jul 19, 2006
    49
    Wayne, MI
    Don't know about the harness, but you can use the ignition hot wire for the eso solenoid (and cold start advance, while you are at it), and to kick on the glow plugs.
