6.2L bolt patterns
Discussion in '1982-Present GM Diesel' started by Sparky87k5, Aug 15, 2002.
  1. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    I have an opportunity to purchase a 90 Suburban 4x4 with a blown 6.2L engine. Having a rebuilt 427 gas engine in the garage makes me wonder the feasibility of swapping it into the Sub. Are bellhousing bolt patterns the same on auto trans? Engine mounts? Sell 427 and purchase 6.5L Turbo'd engine? New to diesels & so much to learn.
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Bellhousing patterns are the same. Engine mounts should bolt in - (not 100% sure - might need different crossmember - but I don't think so).
  3. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    From what I've heard, it can be done (like anything), but you will also need to look into hacking up the wiring harness (or use aftermarket) as well as clean the tank/fuel lines etc. The 6.5 Turbo will bolt in easier as well (depending on the year - they started adding electronic control to both the trans and the injection pump after a certain year). About 95% of the 'hard parts' on the 6.5 will bolt onto the 6.2 and vice-versa (heads, intake, exhaust, etc.). FWIW, I'm pretty happy with my diesel (except maybe that it's non-turbo). azblazor is right though, the motor mounts and trans should bolt right up.
    Jon
  4. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    The diesel has a much lower stall torque converter than a gasser. Another thing to remember.
  5. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    The bellhousing and motor mounts are the same.
    As mentioned earlier, the TC has a lower stall speed, and the wiring will have to be changed.
    A 6.5L TD won't bolt right in because the turbo will hit the A/C evaporator on the old body style truck. It would be easier to rebuild or replace the 6.2L, or install a 6.5L with a Banks system.
    But definitely don't go gas!!!! /forums/images/icons/wink.gif
    Casey
