6.2L Diesel Blazer <- ISO <- What Years??
Discussion in 'The Garage' started by AudieMurphy, Jun 28, 2005.
  1. AudieMurphy
    AudieMurphy Registered Member
    Jun 23, 2005
    19
    VA
    Ive given up on the CUCV idea... So, for a civilian Blazer, what years were the 6.2L installed?
    Is there any particular year that:
    1) Was better than others
    2) Was worse than others
    Also, since Im a diesel noob, is there anything I should be looking for in particular??
    Thanks in advance,
    Andrew
  2. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Shameless self-plug: everything you ever wanted to know may be found in the Brochures pages
    The 6.2 started in '82; the Olds-ish 350 diesel was vaguely available before that, but I think only in pickups, not Blazers, and we don't talk about that abomination anyway. I believe the diesel was available through 1990 or 91.
    There are two styles of intakes, so-called C and J codes (for the VIN digit used.) The CUCV's have the J-code; I don't know what the difference is -- emissions, maybe?
    The one thing I'd be nervous about is the early 700R4's, which are known to be weak; later units, or early ones that have been rebuilt properly, are alleged to be fine. I only have TH350's and 400's so I can't speak to 700's from personal experience. I'd be shooting for as late a model truck as you can, as it's most likely to be in nice shape and have a decent tranny.
    Other than that, the Blazers didn't change much in those years (diesels didn't, obviously gassers got EFI in '87) ... and I am not aware of the 6.2 changing any. I don't believe the 6.5 was ever available in this body style as it came in the early or mid-90's.
    I'm sure others will chime in.
    Oh, both sizes of fuel tanks are available; my CUCV has the 24-ish gallon :angry1: ... so if you can, get the biggun (31ish gallon.) No reason to cut yourself short on range when you get decent fuel economy :D
    -- A
  3. Bunker Buster
    Bunker Buster Registered Member
    Jan 25, 2005
    36
    Lowry Crossing, Tx
    Plenty of CUCV's are available. Keep an eye on steelsoldiers, govliquidation and e-bay. You can pick on up for a pretty decent price with a little persistance. Then again, you could do like I did and just stumble across one for next to nothing. :grin:
  4. AudieMurphy
    Jun 23, 2005
    19
    VA
    Thanx for the updates so far!!
    Andrew
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    let's see...
    87-91 for the revised TH700
    88.5-91 for 30-spline rear
    89.5-91 for 30-spline front
    82-91 for 6.2L diesel
  6. AudieMurphy
    Jun 23, 2005
    19
    VA
    Thank you 2slow! :waytogo:
