6.2L diesel radiators ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Dec 13, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what size/core count are 6.2L radiators 81-87 ?
    are they same as 73-80 454 HD A/C radiators ?
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    34" wide at the core (tanks extra).
    19" tall.
    Can't remember if 3 or 4-core.
    Has tranny and engine oil cooler.
    Will double check when I get home /forums/images/graemlins/grin.gif
    Don't know if its EXACTLY the same a 454 one, but I'm sure it will work.
  3. dyeager535
    26,980
    Actually I think there were two widths available, the one that was almost the entire width between the two batteries, and one that was a bit narrower. If you look at the 81-87 core support where the mounts bolt on, on the passenger side, you will see another set of threaded bolt holes for the wider diesel radiator, maybe 6" closer to the fender than where the "standard" radiator mount is.
    The radiator differences have been covered here before I think.
