6.2L Diesel starter sticking
Discussion in '1982-Present GM Diesel' started by kennyw, Jun 7, 2005.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Trying to get a starter to quit sticking when you release the key. Put a new solenoid on it (old one had a cracked cap). That didn't do it.
    Put in a new ignition switch, that didn't do it (but old one looked burnt anyway).
    Added another shim... no luck yet.
    Bench testing it the bendix returns freely but in the truck it always stays running until the battery cable is pulled. Hook the cable up within 2 seconds of disconnecting and it no longer is engaged.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Had that problem before and it was the rotor, cleaned up all the slots on the rotor and it worked fine after that, shavings get in between the brass plates and get the circuit going till you kill the source.
    At least it worked for me, I had done all the hings you did and then that cured it.
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I've been slacking reading this forum. Anyway, I had the same problem from a fairly new reman Autozone starter. What starter is it?
    Iceman- good info, thanks!
  4. kennyw
    Jun 9, 2002
    13,223
    94
    It was a stock starter as far as I could tell... if he has any more problems with it I told him to just buy the newer style gear reduction starter off of ebay for $99 instead of getting a rebuilt one from the local store.
