6.2L from Humvee = work okay in Blazer
Discussion in '1982-Present GM Diesel' started by 6.2Blazer, Oct 15, 2003.
  1. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Just curious, would it take anything special to install a 6.2 setup for a Humvee into a civilian Blazer (already with the 6.2)?? I know the military has some 24V accessories but could you just swap in the necessary 12V stuff?
  2. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Yes, swap the glow plugs (don't use the resistors)/starter and use all the origional blazer stuff and you should be ok. Check the solonoids on the imjection pump also, i can't remember if they were also 24v or not.
  3. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Yes, alot of HMMWVs are running around with CUCV motors. No reason you couldn't go the other direction /forums/images/graemlins/wink.gif Glow plugs are different (forget about ballast resistors = CUCV exclusive) starter must be civilian 12V, fuel solenoid, HPCA (high pressure cold advance) and it's temperature switch. The coolant crossover needs a plug for the HMMWV "controller". You'll have to add the vacume pump if your K5 used one. Routing the TV cable could prove interesting using the HMMWV intake. The fuel delivery pump needs to be swapped (outlet points at the Xmember). I heard you can use the HMMWV headers, but I have to see it for myself. Also the HMMWV fan clutch uses power steering fluid pressure to actuate it. HMMWVs came thru with shorty (van) style injectors, although some may have swapped to the standard height versions; nothing to worry about just be aware of what you got. /forums/images/graemlins/thumb.gif
  4. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    The main reason I was asking is that you can find complete Humvee engines at military auctions for cheap.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Interesting, then that means that that engine I got from that 1ton truck will need the injectors swapped to go in my van?
    Is it a clearance issue?
    I know the van has a tight engine bay on top and I heard that the turbo 6.5 on a van had the turbo in the back instead of on top or side?
  6. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    I don't know. I've never seen the under hood of a 6.2 van. The HMMWVs seem to clear with either short or long injectors. We worked on a turbo diesel 6.5 (forget the nomenclature XM10??) from Natick Labs that has spent it's entire life idling /forums/images/graemlins/frown.gif(it's a commo carrier). It had the split intake manifold/rear mounted turbo. It was a Motha' Fo' getting the rearmost glowplugs out /forums/images/graemlins/angryfire.gif
