6.451612 MPG on a 355 TBI..WTF? ****Update*****
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by unsane, Feb 3, 2003.
  1. unsane
    unsane Guest
    This gas mileage thing is starting to get out of hand! I just dont understand what the hell is going on! Here is what I have changed and or done to try and remedy the problem.
    New o2 sensor, new plug wires =runs worse now. I am about to get out the 12 gauge and start target practice soon.
    Well I changed the o2 sensor tonight along with new wires(found a burnt one) But guess what? Now it runs like a total POS. My cub cadet runs twice as good. Any ideas before I get out the 12 gauge and start the mayhem.???????
    1. Adjust timing
    2. new fuel filter
    3. injector cleaner
    4. removed beads from cat(thought it was plugged)
    5. DROVE SLOWER
    What gives on this? I would be better off driving a top fuel car to work and back. I am not asking for much maybe 15 MPG or something. Everything is stock except: 0.030 over bored, edelbrock tbi intake, stainless valves. New motor has approx 2k on it. 10 bolts and 31's. Can someone please help me find out where my fuel is going? I just made the ALDL cable tonight so I might give that a try tommorrow. Thanks in advance for the help.
  2. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    Re: 6.451612 MPG on a 355 TBI..WTF?
    i think 15 mpg is too much to ask i get about 8 city 10 hwy
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    What gears are you running? I pulled almost 13 this weekend, but that's on a tired engine, 3.73 on 35's.
  4. unsane
    unsane Guest
    I would have to disagree. 15 mpg with a new motor. Maybe if I were runnin 39 inch boggers and 4.11s or something, but this is stock TBI were talkin here.
  5. unsane
    unsane Guest
    I guess 3.08's or whatever is stock on an 89. I have never changed em. Never have the money, to busy using it to buy GAS.
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    On my trips back to Oklahoma, I've averaged about 16 with a time or two hitting 18.
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    what is your total timing? I picked up about 2-3 MPG just getting my total timing under control.
    also, is your O2 sensor replaced? that might be a culprit, but at 6 mpg, you got some major problem somewhere, IMHO.
  8. unsane
    unsane Guest
    I dont really now how to set total timing. Can you elaborate?
  9. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    On your TBI you need to disconnect the timing advance wire to set the timing, disconect that and set the timing to 0 degrees. The computer adjusts the rest. O yeah I get around 7-9 mpg with my 350 TBI/4.10's/35's, I have 12k on the reman engine also.
  10. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    Yikes! I got 10 in the K30 with 33's and 4.10's, with a 454 and an auto. On the highway of course. My truck now should do a bit better.
  11. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Sounds like it is running in cold start mode all the time. Can you smell the raw fuel in the exhaust?
  12. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Would you be offended if I told ya that kind of mileage sucks? /forums/images/graemlins/grin.gif
  13. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have 350 TBI 3.73 33" tires no lift. I get 15-16 mpg combination average city/ highway driving. Most people I know who have a TBI get fairly good MPG (for a truck) Even my buddies 3/4 ton with 4.10s and a 14sf gets 15 mpg on the highway
    There is definatly something wrong.
    The Ecm may be running in Closed loop because of a bad sensor. Or it may be running in back up mode because of an ECM failure or mulitple sensor failures. Both modes will give bad fuel milage. It was designed this way so the owner would get it fixed.
    You really need to get a scanner on it and check it out.
  14. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    Zakk has a really good suggestion of checking out the O2 sensor. If you haven't replaced it, don't even worry about looking at it, just get a new AC Delco unit and put it in. Also, do you have the stock exhaust manifolds and tubing? The placement of the O2 sensor in the exhaust system makes a difference. I picked up 1.5 mpg just by moving the O2 sensor from the Y-pipe junction, to the driver's side exhaust header. Currently in my '89 Sub I have a 383 / TH400 / 3.73s / 35" tires and I get 9.5 mpg city and highway combined.
  15. caryhenry
    caryhenry Registered Member
    Sep 28, 2002
    78
    Tallahassee, Fl
    Just got a question for everyone... What kind of gas mileage should I expect from an 85 305 3.08 31x10.5x15
  16. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Maybe your calcluator is broken???
  17. zcarczar
    Feb 10, 2002
    2,495
    Yeah I know my mileage sucks ass, I was getting 5 mpg a few months ago, but the previous owner screwed up a lot of stuff when he put the engine in and I dont know what is wrong with it. Hell even the techs i work with cant figure it out. Maybe I need to move my 02 sensor.
  18. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    In days past, my rig was 305 3.73s 32x11.5 BFG ATs with 700R4. I used to get around 9-10 around town and 10-12 on the highway. But I also had a carb in pretty bad shape.
    Most recently I improved to 383 4.56s 35x12.5 BFG MTs still with the 700 but a new carb. I went from around 160 HP in the 305 to 420+ HP in the 383 and my gas mileage is still around 9-10 in town.
  19. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    My K20 with 36 inch Swampers, 4.10's, and a box-stock 350/400/208 just knocked down about 13 on a road trip last weekend. I have been considering an upgrade to TBI and would expect about a 3 mpg gain with it. Are both your injectors firing?
  20. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    my stock 305 engine 84 with 3.73s and 33s got like 6-8mpg city. Never did highway cause she was too unreliable for distances.
