6.5 and 6.2 Parts interchangeability?
Discussion in '1982-Present GM Diesel' started by kennyw, May 4, 2004.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I found a great deal on a 6.5TD shortblock and have traded my way into a complete running 6.2 with an aftermarket ATS turbo (missing compressor side of the turbo however), wiring, even an extra diesel cab for parts... So now I want to build a turbo'd motor using the 6.5 block but what about heads and intake off of the 6.2, are they the same as the 6.5 or will I need to hunt down newer heads and intake?
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    6.2L heads and intake will work just fine on the 6.5L. However, you may find a slight power increase by using 6.5L turbo heads. No need for a newer intake unless the 6.2L is using a C code EGR intake. If so, getting a later model J intake would be better.
    Casey
