6.5 are they any good?
Discussion in '1982-Present GM Diesel' started by 4x4k20, Nov 16, 2006.
  1. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i am looking at a couple 97s with the 6.5 just wanted some opions on them
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you were close I would say no and then ask where the trucks are.:D
    Yes they are good and after 95 I believe all were turbo too.
  3. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    look for coolant leaks,injector pump replacment,or injector driver ( that's the fist that goes out) fuel pumps are week,hard on the injector pump next to be replaced.
    They don't like to run on veg oil due the the photo eye pick up.
    But for what they are there not to bad,Depends on what your plans for the truck.
  4. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Yeah they are pretty good. First power mod should be an intercooler & guages;) Then you can tell how your other power mods are doing before you damage something:wink1:
  5. Wishbone
    Wishbone 1/2 ton status
    Mar 6, 2006
    239
    Oklahoma
    6.5 had turbos since '92. They are a reliable engines and easy to work on. Just don't go in expecting a Cummins or D'Max and you will be fine. Plenty strong for most things and good mileage. First thing you would want to do is move the pmd off the ip if it hasn't been done already. Life pumps do go out but are cheap and easy to replace and very easy to diagnose. Keep the air and fuel filter changed often. Very few injector or glow plug problems with these engines. I love mine.
  6. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Ok moving the PMD should come first and it's easy.:D
