6.5L/465/205/35s........ What gear ratio you think....
Discussion in '1982-Present GM Diesel' started by Batmanjr, Oct 4, 2003.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    OK, First off, this is the MALL cruiser!!! I want to be able to coast at 80 MPH on the freeway and not have to yell over the RPMs! Basically, instead of building it LOW LOW LOW! I want to go backwards and build it for Cruising! So, I was heading towards 3:08s again.... But I already have 3:73s in there! I'm conserned that the 3:73s will be too low to allow the 6.5L to cruise in it's power band.... Any suggestions would be appreciative... Not to mention, What are all you 6.5/6.2 465 guys running gear and tire wise... Thanks! /forums/images/graemlins/thumb.gif
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I think 3.08 are perfect for the setup you are describing.
    35"/3.08/1:1 trany = 2365RPM @ 80MPH, go with 3.73 and your RPM goes up to 2864.
    My 78 Sub that I'm putting the 6.5TD and 4L80E has 3.73 gears which would be 35"/3.73/1:.73 trany = 2091RPM @ 80MPH.....I may go with 4.10's to bring me back to 2298RPM @ 80MPH.
  3. Batmanjr
    Mar 23, 2001
    1,537
    SO I'm assuming that you are pretty much saying that the power range for the 6.5 is between 2000-2500... That is where I should want the RPMs for cruising....? /forums/images/graemlins/thumb.gif
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I can't remember where I got this from, but it was something like 1800rpm for peak economy, and 2800rpm for peak power. (This was for a 6.2L NA) I would assume the powerband is anywhere in between. /forums/images/graemlins/thinking.gif
