6.5L injectors into a 6.2L?
Discussion in '1982-Present GM Diesel' started by kennyw, Mar 10, 2005.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I've seen a few posts about using 6.5L injectors in a 6.2L and I'm considering doing this in my '79 (with a stock '84 6.2L). Any idea what year to give when I have the parts house look up the parts? I'm also not sure if this is worth doing on a stock NA 6.2L either. Not too far down the line I'll be getting a rebuilt IP too.
  2. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    You should look for 92-99 6.5TD injectors.
    Keep in mind that they are a bit shorter than your 6.2 ones. Slightly bend the lines, not a big deal.
    IMHO you won't see better performance with just the injectors. Worse mileage maybe . . .
    With a tuned up pump (to 6.5TD specs) or even a mechanical 6.5TD unit, there's a noticeable gain of power!
    But again, the mileage thing :crazy:
    You should also consider that even with new pump & incectors you still working with the stock intake and exhaust system (have a look at EGT's here). So you may think of an upgrade also.
    Regards,
    Walter
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I'm curious about this upgrade. The only point is to get more fuel injected, right? How would the compatability be with a Banks Turboed 6.2?
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    As I understand it (and I could be totally wrong here...) 6.5 injectors are way overkill for a NA 6.2, and won't even function well when fed by a normal 6.2 IP. (I can't recall the spec; maybe a DB2??)
  5. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Yup, overkill. I did the pump and 6.5 injectors with plans on adding a turbo, but that did not happen nor will it. It smokes a ton, and to be honest i am terrified to know what the EGT's are when im really getting on it. :crazy:
    My recomendation, unless you are adding a turbo at the same time or near future, dont do it. While the smokescreen is kinda cool, its still slower than crap, makes more noise, and uses more fuel if you drive arround with your foot in it. Keep the stuff stock and just turn up the fuel screw a little bit and call it good. Just my $.02
  6. kennyw
    Jun 9, 2002
    13,224
    94
    Sounds like it isn't worth while for now then. I just put in 4 of 8 new stock injectors today. Had to take 2 of them back because they were missing the brass o-ring and will do the other side when they come in.
    I'll look into this when I build a turbo'd 6.2L later down the line.
