6.5L TD to SM465
Discussion in '1982-Present GM Diesel' started by Seventy4Blazer, Dec 13, 2004.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    How easily is this done? do they sell a flywheel that works in this app? as far as i know the 6.5LTD didnt come in front of the 465... mybe im wrong though.
    any part numbers out there?
    thanks
    grant
  2. tRustyK5
    Jul 23, 2000
    36,167
    1,364
    E-town baby!
    6.5 should use the same flywheel as the 6.2. A manual tranny was offered behind the 6.5TD...the NV4500. The donor 6.2 I bought already had the flywheel, pressure plate and clutch disc bolted to it when I got it, so I can't help much with pn#'s.
    You might want to check the diesel part number thread, I think it might be in there.
    The diesel uses a pilot bearing, which some people don't like. I replaced the messed up one on my 6.2 with another bearing (rather than a bushing) and haven't had any trouble with it.
    I have seen 6.2 flywheels on eBay a few times too.
    Rene
  3. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    No, they came backed by a nv4500. The way i look at it though, if a 6.5 NV4500 can be put behind a 6.2, then there should be no reason that a 6.2 SM465 cant be put behind a 6.5. I would think that the NV4500 flywheel would work fine. Dont quote me on it, though, this is just an assumption, but it makes sense to me.
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I would just use the 6.2L flywheel, it is solid Vs the 6.5 dual mass style. I removed a dual mass and installed an older style into a NV4500 equipped truck. You just need to make sure to get the proper clutch for whichever flywheel you go with.
  5. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    I agree with Diesel Dan. Don't use the 6.5L dual mass flywheel, they're known for being trouble when they wear out and come apart. Just use a stock 6.2L flywheel for the SM465. It will bolt to the 6.5L just fine.
    The 6.2L and 6.5L are, in nearly all respects, identical blocks on the outside. A 6.2L will replace a 6.5L, and vice versa. Most of the differences are internal. Therefore, a 465 doesn't know if it's behind a 6.2L or a 6.5L.
    Casey
  6. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    thanks for the info. since i have a brand new clutch installed in the blazer now i think i will just go with a 6.2L flywheel.
    now... anyone have info on 6.5Ltd? i think ill do a search and start a new thread for this one.
    Grant
  7. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    What kind of info are you looking for?
  8. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i just made a new post in this forum.
    thanks.
    Grant
