6.5TD Parts needed to make 6.2L a TD.
Discussion in '1982-Present GM Diesel' started by AzzKicker, Jul 30, 2002.
  1. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    Ok, I'm getting my hands on a 85 K20 with a 6.2. It has 97,000 miles and has been serviced at dealer since purchase. Best part is if I told you the price I'm getting it for, you'd die /forums/images/icons/smile.gif Anyway. I wanna plan this out.
    So I need to know EXACTLY what parts I will need.
    As I understand it. Its recommended to use a manifold off a 6.5 in the 93 model year. as well as the Turbo.
    What else will I actually need to do. The truck has A/C so I understand theres clearance problems with something. Can someone run the process through me.
    I'm not a Noob when it comes to Working on trucks. i'm just a noob when it comes to Diesels. This will be my first.
  2. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    The 93 parts are only the wastegate. The evaporater housing will have to be either removed or relocated. Your injectors will not fit with the turbo manifold. You can get a machine shop to fab a spacer(3/8?). Or beter yet use 6.5 heads, injectors, and injector lines. Try Thedieselpage.com.
  3. AzzKicker
    Jul 28, 2002
    265
    Edinburg, Tx
    So basically if I locate a 6.5TD somewhere. My best bet would be to Purchase:
    6.5 heads, Injectors, Injector lines, Turbo assembly. If needs be, I can remove A/C compressor for NOW. Since By the time I get this truck, and up and running it'll be Fall temps which arent too bad.
    Now with all those parts. What WOULD need to be modified. I heard something about moddint the exhaust crossover or something like that.
  4. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    It's not the a/c compressor that's the problem, it's the evaporator on the passenger side firewall that sticks out too far on the older style trucks.
    A complete Banks setup would be much easier to install, and it will bolt right in.
    A 6.5L turbo system will perform better, but it's much harder to install. There's not that many people who have done it in the older body style trucks with a/c.
    I've seen one truck where the guy fabbed up a turbo mount on the manifold to set the turbo sideways, and had the exhaust down-pipe go thru the inner fender well and down the outside of the frame rail.
    Casey
  5. arveetek
    Mar 1, 2002
    722
    Read this to find out more about what it takes to install a 6.5L turbo system on a 6.2L in and older style truck. (Scroll down a bit on the page when it loads....the info you're looking for is about halfway down.)
    Casey
  6. MRBIGBLOCK
    MRBIGBLOCK 1/2 ton status
    Jun 25, 2001
    472
    paragould arkansas
  7. civicucv
    civicucv Registered Member
    Jul 30, 2002
    7
    NW Oregon
    It's my understanding that the Banks turbo on a 6.2 will outperform a factory 6.5 turbo. I've contemplated adding a whirlygig myself. I received all of the Banks literature and was pleased to read that all necessary parts were included with their kit.
  8. tackettb
    tackettb Registered Member
    Jul 18, 2002
    49
    Tacoma, Wa
    I have a question somewhat related to this. I have a '96 6.5 long block in my '83 Jimmy (no a/c)with all the 6.2 injection system on it. If I scrounge up a 6.5 TD setup, intake manifold ,injector lines, would it bolt right up? Or is there some problem I might have even though there is no a/c and I have 6.5 heads? I have seen a few 6.5 TD's parting out lately. Also anybody have any idea what a used turbo should run $$?
  9. civicucv
    Jul 30, 2002
    7
    NW Oregon
    Try Ebay. Currently, tons of 6.5 parts are listed.
  10. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    The banks turbo kit only comes with all the parts if you have a "J" code intake manifold. If you have an EGR, you need to buy a separate adapter kit as well. I STILL haven't put my kit on, maybe this winter I will get around to it.
