6-8 inch lift, need advice on front drive shaft.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Loose Nut, May 2, 2006.
  1. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    well i lifted my jimmy up greatly and now the Velocity U-joints wont allow the driveshaft to drop low enough. Not only that i have to yank my exhaust off.
    what are my options? i lowered the transfer case but that didnt help, its still 3 inch's short and the bottom of the shaft bottoms out on the CV.
    any idea's? can i get rid of the CV? and still have a semi streetable ride?
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Yes you'll have to lengthen the shaft ( IIRC, I had to stretch mine 2 1/2" - 3 " and also "clearance grind" the CV so it will droop.Grind the little tabs.:grind:
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive got 8" of lift on my k5 with a d60 front with 5* shims and the front shaft works (the d60 pinion is bout 2" longer than 10b) a 1" spacer would work with your setup.
  4. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    i dont see how, since the cv makes it sit about 3 inch's above the d60.
    ill see if grinding out the joint will help. Im also going to have crossmember issues now that i looked at it today.
  5. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
  6. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I have 10" of lift (give or take and inch) and my stock(legnthed) front driveline works. the slip is too short but very little binding, it does bind sometimes but not very hard and never hard enough to damage it.
  7. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    When I had my front shaft lengthened I asked them to cut the tabs off of the CV assembly so it would not bind. Everything works great now.
  8. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    Just so you know I had to grind a little bit more than this but it is not hard at all my angle is probably pretty close to yours condidering my front axle is moved forward about 6" but like the quote said most poeple just have to cut the ears off
  9. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Lowering your t-case will actually put more of an angle on your cv joint because it tilts the output shaft up. Raising the t-case back up will make the cv operate at less angle.
  10. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    if i put it back up then i have to get 2 shafts, and not one lol :)
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i guess it works for me cuz i moved the axle forwardd 1.5" so the angle isnt as bad
  12. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
    When I did my 8 inch lift, I had to get 2 shafts. That is just the price you have to pay. $150.00 to lengthen the rear. $350 to lengthen and modify front cv. My front shaft was rebuilt with a different "H"-yoke in the cv, and I have had no clearance problems and my tranny/transfer case are in the same spot as they were stock.
