6 cylinder engine swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big pappa b, Jan 10, 2003.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    First post disappeared. My new 80 Blazer has a 6 cylinder and I'm going to be changing to a V-8. I have the engine and exhaust taken care of. What else might I need? I'm thinking frame mounts for the motor.
    Anyone done this or can maybe point me in the right direction?
    Bryan
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I believe you will need a 7 blade fan instead of the 4blade that sixes come with.
    You will need the motor mount, and I think you are covered.
    You might have a thinner radiator but I doubt it.
    If you have problems with overheating then you can look for a different radiator.
    When you say you took care of the engine and exhaust, you mean you have all the brakets and accessories right?
  3. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Yes, I have all the brackets and hopefully everything else I need
  4. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Was that the blazer for sale on ebay? Just curious. Some one needed to buy it! /forums/images/graemlins/thumb.gif What gear ratio did it come with?
  5. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Not on Ebay. I bought it here in Delaware from a guy I know. No idea what gears it has yet. I actually pick it up tomorrow when he gets home
  6. sdavid
    Aug 5, 2002
    244
    Livingston, TX
    I think most of the 6 cylinder K5s are low geared. Like 4.10s and have the NP205 transfer case. So you are pretty well set up. You already got what most of us want. Good find! /forums/images/graemlins/k5.gif
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    according to GM specs sheets the lowest ratio ive seen so far thats been available in thes elater trucks is 3.73
    the 6 cyl radiators are alot shorter, they use different upper retainer plate that mounts down on rear side of the rad support instead of at the top like on V8 trucks
    there is also two locations on one side of the rad support for two different lower cushion locations
    get correct engien mount brackets and acc cable stuff and exhaust and you should be alright minus fuel line mods and minor wire mods
    good luck
  8. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    hey I did a swap last year!! I have sm465/205...4:10s.and now the v-8. so far best thing I have done.The flywheel even fit.The motor mounts are also the same.mine is a 77.yours is a 80s the mount brackets might be differant. : /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  9. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    So you didn't have to change to frame mounts? I was just guessing they had to be changed like on my chevelle when it went from a 6 to 8 cylinder
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i wish you lived closer....
    i want a 6 in my wifes blazer.
    grant
