6 inch lift any one???
Discussion in 'The Garage' started by nickdubrule41, May 26, 2005.
  1. nickdubrule41
    nickdubrule41 Registered Member
    May 26, 2005
    27
    massachusetts
    hey guys iv got a pretty much stock 89 jimmy except a 4 inch lift and 33's i have already droppped the transfer case around 2 inches or so to make up for the 4 inch lift i would like to install a 6 inch lift to fit larger tires. and if possible i would like to reuse the drive shafts that are on the truck if possible. if i install the 6 inch lift will i have problems with the drive line angles? what have you all done with yours. any help would be great thanks alot nick.. :)
  2. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    out of curiosity, is there a reason you don't just trim the fenders to fit the bigger tires? Its cheaper (free) and there won't be any of the complications you are worried about. With 4-5" of lift, I run 39.5s... and 42s will come eventually. You don't need a huge lift to fit bit tires.
    more than likely. You can take the shafts you have to a local driveline shop and have them lengthened or you can get custom bling shafts made. Shims between your spring packs and spring perches can help your pinion angle / joint operating angle too.
    j
  3. camok10
    camok10 1/2 ton status
    May 1, 2004
    288
    Tucson, AZ.
    depending on the leafs that you plan to go with, and the amount of flex (if better) you probably will need a longer front shaft, and possible a rear. The same can be said for the angles on your pinion.
    personally i would just chop it up and stuff those bigger meats like jek said. but i know some people are opposed to that and to them i say just stick it in some places that it doesn't fit very well till you dent every body panel you have on trees and rocks, then you wont feel so bad about cutting it up.
  4. nickdubrule41
    May 26, 2005
    27
    massachusetts
    ya your right fender trimming would make more sence. thanks alot nick
  5. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    lift
    even with a 4" lift you still need to add 1 inch to your drive line's so they dont come out in some flexing moment's
  6. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    4" lift and 3" body will clear 38x12.50 tires with no real rub but watch the back corners on the frt fenders.
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Ha, I caught the back edge of my fender with 10" of lift and 35x16" boggers. :haha:
