6 inch lift for 74 blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blaze4999, Feb 7, 2006.
  1. blaze4999
    blaze4999 Registered Member
    Feb 1, 2006
    14
    Quantico, VA
    I have a 74 K5 blazer with stock 31X10.5 inch tires. I'm planning on installing a 6" suspension lift and some bigger tires. I was hoping somone could run me through what lift I should get? What I need to buy? What are the biggest tires I can put on? etc. Also, if I put on a 6" do i need to lower the transfer case, need shims under the axles, need a new driveshaft, is the driveshaft going to catch on anything? Advice is welcome!
  2. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    well what are you going to use the truck for? mud, rocks, trails?i think its safe to say a 4" will let you clear 35's 6"probably 37" and bigger if you hack some fender up. if you go with anything 35" or bigger you should get a crossover steering setup and probably swap out the 10 bolts. id probably go with either a tough country or BDS lift. im sure im missing a couple of things too
  3. nmud2deep
    nmud2deep Registered Member
    Apr 23, 2003
    63
    georgia
    90% of the time with a 6inch lift you have to repace the front drive shaft.. i am running 4in lift and 3inch body with 37x13.50s and i have plenty of room for some 38s if i want ....i am even looking into fitting some 39x13.50 irocs on it
  4. blaze4999
    Feb 1, 2006
    14
    Quantico, VA
    Thanks for the info. How do you guys feel about a 6" with 35's. I don't want to do any cutting on my body, and I think this will be a good setup for trails and mud. Can somone post some pics of a 6" suspension lift on the front end. I want to get a feel for some of the modifications I need to make.
