6 inch lift
Discussion in 'The Garage' started by outlawtorn, Sep 13, 2004.
  1. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    Ive been wondering if I ran a 6 inch lift on my 78 k5 is it a must to get a different longer driveshaft or is there away of getting around it? and on that note what other modifications would i need to make? /forums/images/graemlins/confused.gif
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    you will have to either get a driveshaft place to lengthen it, or get a whole new one.
    with the 6" lift you will need longer brake lines, and stuff to lower your steering.
  3. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    ok so far that doesnt sound to bad
    /forums/images/graemlins/thumb.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Trying to get around driveshaft modification isn't really a good idea. If you're going to band-aid fix anything, a driveshaft is not what I'd choose to be band-aiding.
    If you're after a lift only to achieve a higher stance for looks, just do a body lift.
    Otherwise, do the lift, and modify your driveshaft as necessary to ensure it works.
    NOTHING is worse than a hack job of a driveshaft. Trust me...breaking driveshafts sucks.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]When I went 6" lift I had new driveshafts made. But my stock shafts where pretty worn out anyways. Aprox. $200.00 per shaft.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    He didn't mention if his truck is a 4 speed or an automatic, but if you have a '70s truck with a 4 speed, most likely the front shaft is not going to be able to operate at the angles produced by a 6" lift if you have any kind of flex when you're done and may require an upgrade.
  7. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    What i meant by trying to get around it is like dropping the t-case a bit or something nothing stupid that would make it unusable. 200 a shaft isnt to bad. Mine don't look to bad might just have em rebuilt, we'll see i guess.
    Its a th-350 with an np 203 case.
  8. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    You will need as already said a longer driveshaft in the front and rear..Brakelines,and to correct the angle of the drag link you will need a raised steering arm,
    Stay away from a body lift over 1"...Not needed.
    And with lowering the TC that will make the front driveline more apt to bind up the front CV..
  9. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    alright thanks for the tips mike,oh and what would it hurt to run a bigger body lift?
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Makes it top heavy.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It does? How does a body lift make a rig top heavy, but a 6" suspension lift does not?
  12. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I was thinking the same thing....
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Did I say that ?? Or are you just being Timmay ?? It's not a 4" suspension lift + 2" body lift vers a 6" suspension lift question. It's a 6" suspension lift with a question of adding a body lift or not. But that seamed too be more then you are willing too comprehend. /forums/images/graemlins/rolleyes.gif
  14. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    no need to argue over it was just a dumb inexperienced kid question heh /forums/images/graemlins/blush.gif just disregard it if its gonna cause a problem.
  15. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]That's really not a issue. It's more of someone twisting what someone else says. Besides, a good arguement can be fun from time to time. But on the subject of 6" lifts plus body lifts, I had planned on adding a 1" body lift with new poly mounts, and probley zero rates on both ends. Yes, it'd be top heavy, but I'm more of a mudder then anything else. If you're more into rock crawling, you might want too consitter a small lift and fender trimming. I belive befor giving advice on the propper way too build a truck, that everyone should ask what and how the truck will be used. I wouldn't tell someone building a rock crawler too get a 8 + inch(s) of lift.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Ok, I was just unclear on what you were saying. I thought you were debating 6" suspension and no body vs. stock suspension and 3" body, in which case I wondered how one lift would make the rig more top heavy than the other.
  17. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    to clear it up i meant how would it hurt adding a bodylift on top of a 6 inch suspension lift.
  18. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Okay, simple missunderstanding. But I am dissapointed about no fun arguement. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  19. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] What are your plans for the truck ?? What kind of wheeling do you want too do ??? If you want too go crawling up in the hills, you might be better off with a 4" lift and trim the fenders for tire clearence. With just a 6" lift it feels like it's going too roll when you get off camber. Ask me how I know, almost laid it on it's side on some of the trails up on Silver Mountin more then a few times. But if you're more into mudding, get'er up.
  20. outlawtorn
    Jul 21, 2004
    365
    Box Elder, SD
    ive been up silver mountain didnt like those trails to much. I love the mud but its hard to find around here, and i like an occasional hillclimb and maybe some rocks from time to time.
