6 inch lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jimmy84, Sep 13, 2001.
  1. Jimmy84
    Jimmy84 Registered Member
    Sep 13, 2001
    18
    lafayette, la
    Whats up,
    My six inch lift came in yesterday from Rough Country and i was wondering if i will have any problems with my drive shaft fitting properly after installing this lift. Appreciate the help. Jarret
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I had to run a 1" spacer on the front shaft, the rear I am getting by with my stock shaft...
    Mike
    <font color=green>"My K5 is purdyr than your sister!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  3. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    You might want to get it lengthened. That's about all you really need for a 6" lift. Maybe a t-case drop too.
    Pedal mashed and KICK'N ASS!
    WFO! Wide [censored]'n OPEN!
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    My rear shaft is doing fine. I may get it lengthened an 1" or so down the orad but 2 years on the lift and no problems.
    I would never lower a t-case!
    Mike
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    You will find varying opinions because everybody's rig is different. The thing to remember is the transfer case was not meant to be lowered from the factory location, and the driveshafts were designed (angles and length) to work on a stock height (+/- 1") vehicle. You may get by with stock shafts and jury rigging a bunch of things, but if you ever lose a rear shaft and your rig is pole vaulted, what have you saved. I would suggest getting both shafts lengthened the proper amount. You can use the pothagorian theorum to determine proper length using the stock setup as a base (A (rise) squared + B (run) squared = C (hypotenuse/driveshaft) squared). Also, I would consider running a rear CV from http://coloradok5.com/gallery/Leadfoot
