6 inch suspension lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77BLAZ, Apr 10, 2003.
  1. 77BLAZ
    77BLAZ Registered Member
    Jan 28, 2003
    5
    Hi I have a 77 K5 with a 4 inch rancho lift and 3 inch body and cut out bushwacker flares.I want to install a 6 inch suspension lift. I just wanted to know what brands you suggest and what all needs to be done for the install
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, with 7 inches of lift and cut-out fender flares, you should be able to run some 38's. What size tires are you looking to run with this added lift? I'm going to go out on a limb here and guess you've still got 1/2 ton axles. Before you go 38's or bigger, those axles should be upgraded to 3/4 or 1 ton units.
    As far as manufacturers....Tuff Country Ez-Rides and BDS are good, soft, flexy springs.
    If you'd be so kind as to fill out your profile, that'd be great. Go to "my home" and then chose the personal information selection in the "edit" section. Your profile will tell us who you are, where you're located, and what you drive. Thanks.
