6" lift and 33's ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hardcore, May 9, 2003.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    6\" lift and 33\'s ?
    OK I've been researching some more for my project Blazer. Right now I have the stock 10 bolts but will be searching the junk yards for a Dana 60 and 14 bolt. Until then I wanted to do a little lift and some 33's (I've got 3.42 gears and don't want to pay for gears for a 10 bolt) Instead of getting a 4" lift I figure I may as well get a 6" now instead of wasting money on 4" front springs.
    Does anyone have pics of 6" lift over 33's
    Does the 6" require anything more as far as driveline mods? I know I'll need to drop the t-case and change the steering arm. Anything else I'd need to do?
    /forums/images/graemlins/ears.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/ears.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: 6\" lift and 33\'s ?
    <font color="green"> You won't *need* to drop the t-case, but you may *search* have to. You will most likely *search* need to lengthen the driveshafts, you'll need *search* steering correction and longer *search* brake lines. *search* </font>
  3. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    This is close to what you're asking for, this is a pic of my truck with a 6" Rough Country kit and 35" BFG's...
    I had to get new brake lines front and rear but my driveshafts did work as is. The exhaust crossover is in the way of the front shaft though so I'll have to get that redone soon.
    Personally, I would rather have done 4" with the 35's but I did not want to do any trimming.
  4. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gifWhat is this Search? J/K /forums/images/graemlins/thumb.gif
    I did search and I see that it differs from vehicle to vehicle. Some guys throw on the lift and are good. Others have bad vibes and need new driveshafts. I'll definately do the steering arm and t-case drop and see how the rear shaft does. The rear shaft has a bolt-in spacer to extend it IIRC. I also plan on getting the 11" longer lines since I *searched* and it said the fittings on a 10 bolt caliper are the same as a Dana 60.
    Anyone have pics of 6" lift on 33's, it'll probably look a little weird. /forums/images/graemlins/rolleyes.gif
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yup, you got it exactly right, you'll have to just do the lift and see how it goes. Everybody's truck is a little different. IMHO, you should avaoid doing the t-case drop if you can, people seem to break or crack the frames when the case is dropped sometimes. The ideal way to go would be to have a CV rear shaft made and adjust the rear pinion accordingly, you could definately get away with no t-case drop if you go that route. </font>
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have 8-9" and 35s. Take a look. It doesn't look bad at all IMO, although bigger tires and trimming are on the way this summer. Before I even drive it again, it will likely have 39.5 Swampers and cut fenders.
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I had a 6" lift and 33s. Looked puny.
    -- Mike
  8. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    5" and 32s
  9. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    35s with a 3 inch body lift (i know i know its only a body lift) /forums/images/graemlins/thumb.gif
  10. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I like the full fender look, so I don't really like my 4" and 33's. I like a 4-5" lift with some 35-38" tires and some decent trimming.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I like the "body floating on tires" look. My truck looks just like my friend with 15" and 44s, only smaller. /forums/images/graemlins/wink.gif
  12. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    6 inch lift with 33 inch BFG Mall Terrains and fender trimming. [​IMG]
  13. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    33's and 6"...
  14. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Thanks for all the pics guys. Hopefully it will only be 33's for a little while and I can get the axle swap done so I can put on the 38's!!!!!! /forums/images/graemlins/thumb.gif
  15. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    I have some 38's waiting to go on mine too. 33's with cut fenders and 6 inches of lift looks goofy.
  16. GREASEMONKEY
    GREASEMONKEY Registered Member
    Dec 15, 2002
    17
    Centreville, Va.
    I have a 6" lift on mine. Had to cut and extend exhaust pipe that goes around front drive shaft, extended steel braided brake lines. The 33" will look rather small (that's what I have) go with 35" . and I dropped the Xfer case, came with the kit.
  17. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I think 6in and 33's looks kinnda cool with out cutting the fenders but then agin the 35's with 6in looks RELLY good /forums/images/graemlins/thumb.gif
  18. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    now this is what you call body floating on tires!!!!! that is 13" leafs, 3" body lift and re-enforced shackles that lifted the front 2-3 inches more!!!!!!! and a 2" block in rear
    but the body lift is off... and front leafs are going...
