6'' lift and 35's pics
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by twosnvrlose, Dec 2, 2006.
  1. twosnvrlose
    twosnvrlose Registered Member
    Jun 4, 2006
    27
    Canada
  2. twosnvrlose
    Jun 4, 2006
    27
    Canada
  3. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
  4. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Good looking K5. Would enjoy seeing more pics of it.
  5. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    6" lift with 35's is a good looking combo IMO.
    Show us more.
  6. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    proportionally the 6" lift and 35's looks the best. And probably the cheapest too. Seems like the 35" tire has so many brands and models to choose from.
  7. 89sammy
    89sammy Registered Member
    Jan 31, 2007
    29
    chicago
    what lift did you use? i have a set of 35x12.50 baja claws that i want to put on my new 72 but since this is my first k5 I am unsure of how to achieve the proper lift to clear them.
  8. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Looking good
  9. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Any 6" lift would be great for clearing those. Lots of people like Tuff Country - I run Skyjacker - Superlift is okay - whatever you can afford will work out great - oh and I see you are relatively new - welcome! :D
  10. 89sammy
    Jan 31, 2007
    29
    chicago
    thanks for the welcome and i can allready see that I am going to love it here. i have always had samurai's and tracker's as my offroaders but I am ready for some horsepower and since someone just gave me a 72 blazer I figured why not build a nasty rig out of it. I have a crate 475hp 406 on the way for it.:D
  11. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    89, what do you have in mind for your 72?
  12. 89sammy
    Jan 31, 2007
    29
    chicago
    well since i am new to these full size rigs I am unsure but I think I will keep the axels for now and swap gears with some lockers get a good lift on her and get it painted. it was given to me with no motor,trans or interior also no tailgate or top but hey the price was right FREE:D, i will be caging it and it will be used mostly as a trailrig but it will hit the road sometimes.
  13. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    you might think of swapping at least 3/4 ton running gear under it. Pretty easy swap and the strength you'll gane will be worth it plus gears are easier to setup in a 14FF and a detroit is only like $325 for it.
  14. 89sammy
    Jan 31, 2007
    29
    chicago
    i think i will, there is a set out of an 87 chevy laying at the farm.
  15. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    yeah mostly bolt in on the front. Rear if a 3/4 ton will need to move the spring perches in an inch per side. I used ruff stuff perches and worked really nice. Also depending on the shaft you use might have to run a hermorphidite u-joint from 1310 to 1350
  16. 89sammy
    Jan 31, 2007
    29
    chicago
    thanks for the info, the rear is a 14 bolt so i will order up some perches when that time comes and as for the u joints I will be ordering all new shafts anyway.what t case is in this beast? its an auto with a small block.do you know what gears will be in the 3/4 ton gear, it is out of a 87 with a small block auto. thanks again for all your help. I hate being a newbie but if you ever have or know anyone that has a samurai or tracker then maybe I can return the help.
  17. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    hard to say what setup is in the truck. Pull the diff cover and on the edge of the ring gear you will see some numbers. the last couple numbers wil be like 41 10. Divide the numbers and 41 10 would be 4.10 gears, etc. Also make sure it is a 14 bolt full floater.
  18. 89sammy
    Jan 31, 2007
    29
    chicago
    how do i know if it is a floater or not?
  19. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
  20. vtblazer
    Sep 30, 2003
    2,471
    Central VT
