6" Lift and Drag Link
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigTex, Aug 6, 2001.
  1. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    6\" Lift and Drag Link
    For those of you with 6" lifts, how necessary is it to get an adjustable drag-link? Is the steering arm good enough, or should I go for both? I know not everyone has the adjustable drag-link with the 6" lift, so I wanted to see if I should spend the extra money or not. Can anyone out there help?
    <a target="_blank" href=http://www.chriswhitley.com>www.chriswhitley.com</a>
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Re: 6
    Ive gota 6" lift and have a raised arm and dropped drag link.With the 2 I have very little bump steer.I think it was worth the money.
    POWERED BY CORONA<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Re: 6\" Lift and Drag Link
    I am running 6" Super Lift Superrides springs in the front and am running just a 4" raised steering arm.. So far so good... My tie ord are new and my draglink isn't very old. I am running a rockrod with a stock steering stabilizer and get very little bump steer...
    Mike
    <font color=green>"It's like a sore dick deal, You cant beat it!"</font color=green>
    &lt;a target="_blank" href=http://www.geocities.com/emmettology101&gt;www.geocities.com/emmettology101&lt;/a&gt;
  4. BigTex
    Dec 27, 2000
    974
    South Texas
    Thanks, guys. Anyone else out there feel the extra dough for the drag link is justified?
  5. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    I think you should go with the drop pitman arm and a raised steering arm and you angle on the drag link would be pretty flat, and its cheaper than the adjustable drag link. Although I did replace all steering components while I was at it but only because the previous owner never lubed them and where pretty tore up.
  6. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I went with the Superlift adjustable drag link and steering arm and I am happy I did. Of course, i got mine for cheaper since we carry Superlift, but if you want one, I can get you a price on it. Just email me at keith@autoaccessory.com
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I currently have a drop pitman arm and a raised steering arm and the steering is ok. Have some bumpsteer, but hope to clear that up w/ some sway bar disconnects. I was told that the S or 2' drag links don't work well w/ a raised steering arm which is why i went w/ the pitman arm... not sure if it is truw or not cause have heard of plenty of guys w/ that setup.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't use the drop drag link. I would only consider the steering arm and pitman arm. Right now I've got the steering arm and a 4". If I go bigger the pitman arm goes on. If I go bigger than that, crossover will be necessary.
    Tim
  9. BigTex
    Dec 27, 2000
    974
    South Texas
    Thanks, Mikey. I think that is what I'm going to go with.
  10. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    Re: 6
    dropped drag link does absolutely nothing to alleviate bumpsteer. all it does is help the tie rod angles.
    i am wondering how many people know what bumpsteer is
  11. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Re: 6
    I had the raised arm with a 4" lift.Very little bump steer and a good turning radius.I put on new 6" front springs and my turning radius sucked and I had a bump steer problem.Got the dropped drag link and it helped both problems.And yes I do know what bump steer is.
    DONT SWEAT THE PETTY STUFF,JUST PET THE SWEATY STUFF<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
