6" lift and driveshafts
Discussion in 'The Garage' started by bigboy, Nov 28, 2005.
  1. bigboy
    bigboy Registered Member
    Nov 8, 2005
    51
    Lafayette, IN
    Ok guys i have another question ya know tryin to get some answers before i start building. I have a 1990 k5 all stock except for 33" tires and want to put a 6" suspension lift on it going to go with add a leafs and blocks in back do i need to get my driveshafts lenghthed??? I know they sell transfer case lowering kits and say that you dont have to do any driveshaft modifications but dont know what to do MONEY is an issue on this build. I have a very tight budget as most 17 year olds do and the truck is mainly going to be used on the road but will be taken to the badlands a local off road park about 2-3 times a month mainly mud, hills, ect... not much rocks or anything like that or not as planed anyways. What do you guys think. I am trying to do the entire truck for about 1500-2000 total not including tires tho so like 1500-2000 for lift, dimondplate floors, used 14bolt axles, fender flares and some sheet metel to get rid of some rust.
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    a buddy had 6" on his k5 and didnt have to lengthen, but it would have helped. it shouldnt be too much to get it lengthened a couple inches
  3. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I had to lengthen mine,and clearance grind the front, as not to bind up...
  4. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i had to. i did the same lift and the shaft pulled out sometimes. it cost ne $115.00 to GET ER DONE. sorry. :doah:
  5. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    cv wouldnt be a bad idea
  6. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    If money is really an issue, than skip the 6" lift. Go 4" which will clear 33's fine, and relieve driveline issues. Forget the flares and combine the money saved, and lock your rear end.
  7. bigboy
    Nov 8, 2005
    51
    Lafayette, IN
    Yeah but i want to go with 36"+ tires eventually
  8. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    many people run 38's and 40's all day long with 4" lifts.... its all in the :hack: :wink1:
  9. bigboy
    Nov 8, 2005
    51
    Lafayette, IN
    Does anyone here have pics of a 4" lift and some 40" tirs or 38.5" tires???? I want to see some pics because A 4" lift is quite a bit cheaper than 6" lift ya know. But I also want a 3" body lift just to make it look bigger.
  10. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    YUP!!! Just what he said! And if U are gona run tires that big, it will "look big" without the body lift.
  11. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Everybody has a 'look' that they hope for. And for some, the look is more important than function. You need to decide which it is for you. If function is what you are looking for than don't worry about looking big, you can achieve the look down the line when finances allow. You'll be much happier in my opionion with a truck that works well.
  12. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    What he said.
