6" LIFT, ANYTHING I AM MISSING?
Discussion in 'The Garage' started by bscappell, Oct 21, 2004.
  1. bscappell
    bscappell Registered Member
    Oct 4, 2004
    10
    washington
    6\" LIFT, ANYTHING I AM MISSING?
    OK,
    Wanting to lift my 88 k-5 6":
    FRONT: 6" springs of some sort, f-250 long travel setup and pro comp monotube shocks with limiting straps and new brake lines. Greasable bushings. also ORD sway bar disconnect also new lift schackles from hill 4 wheel drive.
    REAR: 2 inch springs of some sort and ORD shackle flip kit. Not sure what kinda shocks yet, new brake lines as well. greasable bushings all around.
    my ?'s:
    People have told me both ways about:
    Transfer drop kit, need it or not?
    Sway bar drop kit, need it or not?
    And also the hill four wheel drive website talk about castor condition caused by these shackles, any idea about that? hill four wheel drive
    Anything else I need to worry about?
    probably be a 85% road and 15% trail
    Gonna run 35's with it.
    thanks,
    Brandt
    Washington /forums/images/graemlins/usaflag.gif
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Re: 6\" LIFT, ANYTHING I AM MISSING?
    you will prolly have to drop the t-case but that is not hard at all.
    You will also have make sure your driveshaft is going to be long enough for the 6" lift, I have heard of some people having to get theres extended.
    Also the angles at which your angles run at might need some adjusting, the angle at the t-case and the angle at the pinion should be parallel to each other for a vibe free ride. /forums/images/graemlins/thumb.gif
  3. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    you can use Procomp shocks in the rear as well. ES9000 are good.
    You will need to get a drop kit for the sway bar for it to line up properly.
    Yes, you will need to address your steering as well. You will probably need a steering arm or drop drag link.
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    OK,
    FRONT: . also ORD sway bar disconnect
    my ?'s:
    thanks,
    Brandt
    1. The swaybar disco's will take care of the sway bar drop.
    2. The shackle flip will point the rear axle pinon at the TC. So you will either need to change the mounts on the axle or better is to change the rear driveshaft to a High Angle 1 ton CV at the same time. /forums/images/graemlins/waytogo.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You didn't mention gears to turn those big tires. /forums/images/graemlins/deal.gif
    You have PM.
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I would throw the sway bar in the scrap pile. I would NOT use a t-case lowering kit because it will make the front driveshaft angle worse; it is already going to be worse than the rear shaft angle, don't make it extremely worse.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'll agree with both of those. Yank the front swaybar once you put the lift on and drive without it for a week. I havne't had a single customer, or myself, want to put it back on the rig after that.
    Oh and forget those shackles. You don't need to spend $60 on some metal with holes in it....what a rip off.
  8. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Never had a problem with driveshaft length at 6in.,but check your cv for clearance... /forums/images/graemlins/usaflag.gif
  9. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    New Drive shaft or an extended one! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
