6" lift...can i get a kit for a 3/4 ton?
Discussion in 'The Garage' started by 58 apache, Jan 10, 2007.
  1. 58 apache
    58 apache 1/2 ton status
    Aug 26, 2006
    377
    clarksville,Va home of the body bag
    so i want to order a 6" spring lift for basically an 85 k5 has 10 bolts now ,58 apache body. every place i call they overload me with options heres what i got and what i think i need..
    85 k5
    d60
    14bff
    37x13.5
    front
    6" front springs
    d60 spring plates (not with the d60)
    u bolts kit for d60
    raised steering arm & block
    shocks
    longer brake lines
    sway bar drop bracket
    rear
    6" 52" rear springs
    1 ton u bolts (do i need different spring plates goin from 10 bolt to 14bff)
    shocks
    longer brake lines
    will i need different yokes or driveshafts or anything else to do this axle swap and lift? i know i gotta move rear perches. what do i do about ebrake cables?
  2. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    In the rear I went with a 3" spring and a 4" ORD shackle flip. It actually gives me 7" but once I throw some crap in the back it levels out pretty good. Just my .02 cents worth
  3. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    1. I would also get a shackle flip and either 2 or 3 inch springs in the back
    2. yes you need new spring plates for the rear. 14b has bigger tube and u-bolts
    3. I would ditch the sway bar on the front.
    4. if possible, mostly funds permiting, do crossover instead of getting all the bandaids for the stock steering. with a d60 cost wont be near as bad as with a 10b.
    thats how I would do it but everything else looks good to me.:D
  4. mjnemmer
    mjnemmer Registered Member
    Oct 17, 2006
    12
    sonora,CA
    you will probly also need a conversion u joint or a new yoke fot the driveshaft going to the 14bff. im going through that part now.
  5. 58 apache
    Aug 26, 2006
    377
    i was told being mostly show and go and with the tourque produced that a shackle flip wasnt a good idea i was told springs and anti wrap perches. possibly trac bars.
  6. 58 apache
    Aug 26, 2006
    377
    so just talked to another vender who said i can get tuff country's 3/4 ton kit with rear 52" springs and this will give me everything i need including the d 60 u bolts and 14 bff u bolts and steering correction is that right? i can get a 3/4 ton kit for my 1/2 ton k5 frame with a d60 and 14bff?
  7. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    if you need anti wrap perches and and traction bars without a shackle flip then you might as well go with the flip. it will ride better since you can use a spring with less arch. I agree with everyone else on the crossover. don't waste your money on cheap fixes. the truck will steer better with crossover even if the biggest thing you ever drive over is a speedbump.
    most lift kits are the same for a 1/2 or 3/4. you will need a conversion joint for the rear shaft or you could have the right yoke welded on to your shaft. You will probably need a longer rear shaft anyways. the front shaft will be good becasue the yoke on your 60 sits back further then the 10 bolt thats there now.
    If you want to keep the swaybar then you should get some type of disconnect. The swaybar needs a point to move just like the springs. Your front springs have shackles so they can extend when you hit a bump. the swaybar will keep the axle from moving if you do not correct it somehow.
    I personally think you should just ditch it.
