6" lift front shaft?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sled_dog, Sep 3, 2002.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    6\" lift front shaft?
    With a 6" lift on the Blazer would I need to change driveshafts? Either front or rear? I read something on Superlift's site(brand I will go with) about having to grind the stock CV joint with a 6" lift. Anyone know anything about that?
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    Re: 6\" lift front shaft?
    i dont know about that..but i know you will need to probobly extend your drive shaft or get a custom one..due to the extreme angles your shafts will be at, with a 4 inch lift thats about as high as you can go usually with out possibly having to do that..
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I had to extend the front shaft, but didn't have to clearance it for regular use. When I get longer shocks that will allow more droop then I will have to do some clearancing. </font color>
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have the shortest stock driveshaft a truck can come with and all I did was grind all the stops off and it works on my truck. I have a 6" suspension. I have not checked it with full wheel travel though I suspect it'd be quite short.
