6" Lift Kit
Discussion in 'The Garage' started by Mudbug1979, Oct 15, 2003.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    6\" Lift Kit
    If I'm taking off my 4" suspension and putting on a 6"suspension will I have to lenghten the rear driveshaft. Some say yes and some say no. Just to recap I have a 350,th350,203, 14bolt rearend. Transfer Case is lowered and I gained about an 1" and a half. I've also been told to take the front brake lines out of the front frame mount and place it beneath the frame and tie it up out of the way. I realize that the rear drive shaft will eventually have to be lenghten and every application is different but I just need to be able to drive it about 15 miles back to my house from the shop where it would be installed. Thanks Again /forums/images/graemlins/thumb.gif /forums/images/graemlins/ears.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: 6\" Lift Kit
    Yeh I got the same response when I asked about rear shaft, far as I came up with it was this, yes or no it all depends on your rig. So to me I always planned on needing to.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: 6\" Lift Kit
    I have a 6 incher and didn't lengthen my shaft. It makes me nervous and I think I'm going to have both front and rear shafts made. I have been running the stock shafts for almost 2 years though and haven't had a prob.
  4. Mudbug1979
    Aug 4, 2002
    439
    Re: 6\" Lift Kit
    Thanks for the responses. /forums/images/graemlins/thumb.gif
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Re: 6\" Lift Kit
    If you point the pinion up so you have proper driveline angles it should be alright but at the same time a little sketchy.
    Somewhere in the past I made a post about brakehoses. I like the factory mounting since they go through the frame instead of under and have real brackets holding them.
    Front brake lines:
    These ones are for the left front of a 1994 2wd 1 ton and are around 25" long. $13.99 at Advance Auto. Napa wants $16.69.
    Tru-Torque (Advance Auto): H38873
    Napa: H38873
    Bendix: 78227
    Raybestos: BH38873
    Wagner: F124600
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Re: 6\" Lift Kit
    Front brake lines:
    Napa: H38873
    Bendix: 78227
    Raybestos: BH38873
    Wagner: F124600
    [hijack]
    Do you know if those hoses will work on a 10 bolt and D44 caliper?
    [/hijack]
  7. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Re: 6\" Lift Kit
    I know it works on the 10mm banjo (10 bolt) but I don't see why it wouldn't work on a 7/16" banjo (Dana 44) even if you had to modify it a bit. We're talking like 1mm difference and I'm pretty sure my banjo bolt slopped around a lot more than that. I know my 77C20's caliper's banjo bolt went through but I don't remember if it was 7/16" or 10mm.
    I don't know, I'd call up the auto parts store and see if they've got the brakehose and then stick a 7/16" banjo in it.
