6" lift question
Discussion in 'The Garage' started by BamBamblazer, Oct 16, 2002.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    6\" lift question
    I want to put a 6 inch lift on my blazer and i have questions first. Will i need a new driveshafts with 6 inches or will the stock ones still fit? /forums/images/graemlins/frown.gif I really dont have the money for a new shaft right now as i have just put a new motor and tranny in the blazer. /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/k5.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: 6\" lift question
    I think the stock shafts are really pushing it on 6" even with dropping the tranny down. I tried it and had no luck. Maybe other people have. Good Luck.
  3. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    You need to shop around for driveshaft shops. Here re-tubing a front is like 40 bux since you don't need to balance a part-time. Rear is about 110 for a re-tube on rear and balanced.
  4. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    I've got a 6" lift on my blazer with stock drivelines. I've had it flexed to the point wheir I had a tire off the ground and haven't pulled a driveline apart yet. But I am planning on new drivelines as soon as money allows.
  5. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I have a 6". My rear shaft is OK but my front is too short.
  6. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    By lowering the t-case and adding a driveshaft spacer to the front, you *might* be able to make it work. Definately wouldn't be the most ideal set-up though, IMO.
