6" lift questions
Discussion in '1936-Present Suburban' started by chvyhs, Jan 19, 2002.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    6\" lift questions
    I put a 6" lift on the Sub and I want to know if I need to lengthen the drive shafts. I pieced the lift together there's no instructions. Thanks.
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Re: 6\" lift questions
    Drive it. If there's vibration you'll at least need to lower the T-case. Go somewhere to max out the suspension and see if the shaft stays in the case. if it's ok, then you don't have to lengthen them. I did a 6" lift on an 86 k10 and we didn't need to lengthen the shafts.
    Red 1989 GMC Suburban SLE V1500 - TBI 350, 700R4 w/ shift kit, Quad-shock front, 31/10.50/15 Pro Comp MT, 4.10 gears, Duals off cat
  3. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    I did not have any problems when I lifted my '79 K10. The only thing that I had to do was grind a little in the front driveshaft CV to stop it from rubbing
  4. swiggettbj
    swiggettbj Registered Member
    Mar 17, 2002
    7
    Paris Kentucky
    I also have a 6 inch lift on my 91, I shimmed the transfercase down in the rear 1 inch. The front drive shaft came up about 4 inches too short. The brake lines will be tight enough to play music on. All you have to do is go down to the local parts store and get brake lines for a 2 wheel drive Sub.
  5. chvyhs
    Feb 12, 2001
    1,469
    I put the 6" SuperLift brake lines on. I'm still not sure if I have to shim the T-case. I have to get a longer drive shaft for sure, when I do that I'll have my front checked.
