6" lift questions
Discussion in 'OffRoad Design' started by aj_tatted, Sep 19, 2003.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    6\" lift questions
    hey guys, i started putting on my lift today and relized how far the drive line was extending. was is a exceptible length for it to be pulled out? also when pivoting my tranny what is the best possible way of doing that? i thought of putting spacers between the crossover brace and the frame but i'm not sure if this is how it's done. the distance i'm speaking of is out of the transfer case, currently it looks to be about 4". is this o.k? /forums/images/graemlins/1zhelp.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: 6\" lift questions
    Sounds like it might be too much. I think I would drop the transfer case down and then look at it again.
    You are correct. Put spacers between the frame and the crosspiece.
    You still might have to get your driveline extended. Every vehicle is different.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    AJ, is any of this still relavent? It must have worked OK since you were in Moab with it. I don't know what happened to this post, it's kind of old and this is the first I've seen of it.
    Sorry
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well since he broke his transfer case off the back of his tranny I think this is the least of his problems... /forums/images/graemlins/eek.gif
