6" Lift Recommendations
Discussion in '1936-Present Suburban' started by BurbLover, Nov 29, 2004.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    6\" Lift Recommendations
    I've got a nice 89 Conversion Burb that I'm gonna lift for a maal-cruiser on steriods. I traded for a D60/14FF from a CUCV. Both have 4.56's & a Detroit in the back. I've got a set of 35's at a buddies house that' he's just wiating for the $$ on /forums/images/graemlins/whistling.gif
    Anyway, once I pay the tires off, I'm going to lift the girl. Thinking 6" as it has the nice fiberglass ground effects. I want an extremely stiff rear spring so that I can tow with it. I know most lifts are soft so I thought of adding an overload to the rear pack. This will also offest the fact that the D60 sets about 1 inch above the 14BFF.
    So, I'll be needing front springs, rear springs (56"), shocks, and the 4" lift block for the D60. What recommendations do you guys have?
    Also, when I order the rear springs, If I order the springs for an 87 K20, will the rear springs be the same since I'll be needing the 14BFF u-bolts?
    TIA. /forums/images/graemlins/waytogo.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: 6\" Lift Recommendations
    Mark, Kevin and I snagged a set of 56 inch springs from a 3/4-ton pickup at A1 and they bolted right on my '90 Sub. /forums/images/graemlins/thumb.gif
    If ya want a really stiff ride, then Rancho or Procomp will probably do the trick. /forums/images/graemlins/eek.gif
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    find a comertal truck spring shop have them make you springs they could do anything you wanted.
    have like 12 ton springs or something stupid in the rear.
    or rape the springs and hangers from a 1 ton and flip it /forums/images/graemlins/dunno.gif
  4. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Since I'll be towing with the vehicle, I can flip the rear hangers. I am really just looking for opinions on brands of 6" lifts. Thanks.
  5. sublmnl1990
    sublmnl1990 1/2 ton status
    Nov 8, 2004
    419
    Virginia Beach Va.
    Once I finally went with skyjacker there is no going back for me. I have tried several others and I will be their poster boy if asked. /forums/images/graemlins/burb.gif
  6. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,044
    1,115
    Dallas
    I am happy with my Tuff Country 6" setup. Regular 48" springs in the front; 56" spring in the rear. It rides as well as can be expected from a lifted suburban, and handles loads well. All in all, a very stable and balanced ride.
  7. LilWes278
    LilWes278 Registered Member
    May 8, 2003
    71
    Turlock, CA
    I've got the Superlift 6" on my 1 ton (blocks in rear). It rides soft enough around town, but since I kept the big ass stock springs in the rear, it still tows like a champ. And even though I've got a big block, the front springs haven't sagged at all. The only thing I am going to change is adding a set of zero rates in the front for more tire clearance (you shouldn't need to do this for your mall crawler), and a flip kit in the rear. You might want to really think about using a set of 1 ton springs in the rear for towing, as it would probably help eliminate the infamous "Suburban Saggy Butt Syndrome" too.
  8. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    lift info
    i wouldnt get the dana 60 block. i would get the drop arm for the box. about the same price and much easyer to install on truck. had block on mine didnt like fealing of it much better with arm. good luck with project and when done post them pics dude.:grin:
