6" lift with a 454
Discussion in 'The Garage' started by MEGALADON, Jan 20, 2006.
  1. MEGALADON
    MEGALADON 1/2 ton status
    Feb 4, 2005
    214
    HOUSTON
    Would having a 454 hooked to a automatic and 208 T/C with all stock running
    gear be ok. I know that a 6" lift changes the drive shaft angles and I don't want to be breaking anything. the 454 has a mild build. it not an all out race motor, just a strong street torqe monster. I will run 35" tires also. If I do the
    6" inch springs, front and rear, will I have to zero rate the springs.
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Which running gear ???
  3. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    I mean all stock drivetrain :D
  4. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    296
    Truckee, CA
    which drivetrain? 1/2, 3/4, or 1 ton
  5. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    Its a 1/2 ton.
  6. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    454 with 1/2 tonners and 35's! snap! The tires should fit and youll need zero rates if no trimming is done and you want to stuff the tires. if you dont stuff tires then it will work as is. F the zero rates and trim is my .02
  7. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    Crackle,Pop :yikes:
  8. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    If your angles aren't real stupid. There was a truck running around here that was a 1/2, strong 454, dunno bout what axles and trans/case, but he was breaking u-joints with 40s. I guess it had a pretty nasty shift kit that would bark the tires, and thats how the joints kept snapping.
  9. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    I really had that feeling.
    Would a 4" be a better idea.
    I am using for a DD only.
  10. walla2k5
    Sep 5, 2004
    2,054
    Walla Walla, WA
    The size of your right foot will have a lot to do with carnage.
  11. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    On the street I would think the 10B rear could handle even a decent 454, on the street it can't get a big shock load like it could offroad. I would think the 1/2 drivetrain would do ok.
    Offroad is a different ball game.
