6" lift
Discussion in 'The Garage' started by bigwalleye, Aug 29, 2005.
  1. bigwalleye
    bigwalleye Registered Member
    Mar 7, 2005
    38
    Portland
    On a 76 blazer what do I need to change in the front to run a 6" lift spring is it just the ds length or do you have to do a cut and turn to help out the pinon angle?
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    you have to worry about steering, brakes, springs, shocks, and driveshaft, i'm not sure if you should shim the axle, someone here will tell ya though
  3. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    My pinion angle was fine with a 6" lift just lengthened (sp? :confused: ) a bit :D
