6" Lift?
Discussion in 'The Garage' started by Quicksilverb33, May 28, 2006.
  1. Quicksilverb33
    Quicksilverb33 Registered Member
    May 28, 2006
    8
    Wake Forest,NC
    Im looking for a good/cheap 6" lift for my 89 blazer. i have a 3" lift with 33's but my front Leaf Springs are beyond flat and now my tires are rubbing but not that bad. Anyways im trying to find a 6" but dont know if i should use blocks in the back or not. Need Some INFO....if anyone is sellin a lift or advice on what i should use.....
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    are you planning on going up in tire size as well?
  3. Quicksilverb33
    May 28, 2006
    8
    Wake Forest,NC
    yes im hoping to fit some 35's on there
  4. resurrected_jimmy
    May 23, 2005
    2,241
    For off the shelf springs I like skyjacker softrides. They have worked well for me for general truck abusing.... mudding, trails, street. In the back do a shackle flip and either a 2" add-a-leave or a block.
    Can you tell us what drivetrain combo you have?
    engine/trans/t-case/axle ratio
  5. Quicksilverb33
    May 28, 2006
    8
    Wake Forest,NC
    Yea b/c right now i have R/C lift 3" leafs in the front and an 1 block in the back with 2" leaf. Which i have a feeling that my fronts where too soft for the way i drove when i went wheeling and now thier beyond flat haha but yea i might just go back to soft b/c im thinking about stop wheeling for awhile since its the only truck i got
  6. resurrected_jimmy
    May 23, 2005
    2,241
    Found this for sale in the classified section http://coloradok5.com/forums/showthread.php?t=173955
    I don't know the guy but it looks like it would suit your needs allright. Rancho's tend to be stiff and a 4" lift will clear 35's so you don't really need to go any higher.
  7. Quicksilverb33
    May 28, 2006
    8
    Wake Forest,NC
    thanks i might use him as a last request i have been told that i shouldn't use blocks in the back. B/c one of my friends owns a 90 model 2-door Thaoe sitting on 37's TSL with a 6" lift no blocks man i could say that thing looks Good. but i haven't seen him much to get the info i need from him
