6" lift
Discussion in 'The Garage' started by FL84K5, Mar 12, 2003.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    6\" lift
    Finally, never thought I'd see the day this thing got lifted. Now I need bigger tires. [​IMG]
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Re: 6\" lift
    So did ya flex it out in the pit? /forums/images/graemlins/thumb.gif
  3. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    Re: 6\" lift
    Soon, soon my friend. I can't wait to test the flex out. /forums/images/graemlins/grin.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: 6\" lift
    Let's hear about it. What springs did you go with ??? What'd you do in the back, springs, flip, blocks, ... ect ??
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Re: 6\" lift
    LOOKS GOOD!!!
    What size are those? 33's? Looks like you got room for 38's with no problem
  6. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    Re: 6\" lift
    I'm running Tuff Country 6" front springs with an Echobit flip in the back and an ORD zero rate in the back. The zero rate was also used to move the axle back after the shackle flip. I was afraid the stock rear springs were going to be sagged bad in the rear causing it to sit low, but it sits nice and level. It's got some vibes so the rear is probably going to have to be shimmed. Putting a spacer on the front shaft and the crossmember for the t-case might need to be trimmed so the front shaft dosn't hit it. Yes, those are 33s. They look even smaller than with no lift and the fenders cut! I'm going to be running custom grooved 38x12.50 TSLs. [​IMG] [​IMG]
  7. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    Re: 6\" lift
    it looks good I want a blazer
  8. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    Re: 6\" lift
    I like your trim job, did you have to remove your inner fender to get the front fender trimmed that far? Looking good! /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  9. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    Re: 6\" lift
    No, I didn't have to remove the inner fender at all.
