6 Lug 14 Bolt Axel
Discussion in 'OffRoad Design' started by 1972Blazer, Oct 17, 2001.
  1. 1972Blazer
    1972Blazer 1/2 ton status
    Jan 2, 2001
    238
    carlsbad, California 92009
    Is there any way to get or convert a 14 Bolt Axel to a 6 Lug Chevy Pattern. I was told a few years back that the 90-93 SS454 Trucks had a 14 Bolt in them and so did some Heavy Half and Z-71's around the same time. Any help would be appreciated.
    1972 Black CST Blazer, 350/415 HP, TH350, NP205, 4" Springs Front/Rear, AGR Variable Ratio Steering, 15X8 Ralley Wheels and 35X12.50 BFG Mud Tires.
  2. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    Some of the light duty 3/4 ton 88's and up came with a 6 lug semi-floater 14 bolt. Has a 9 3/4 inch ring gear compared to the full floaters 10.5 . The same axle could come with 8 lugs too.
    I believe O.R.U. Sales a kit to make a full floater 14 bolt into a 6 lug.
    4 wheeling is like sex, when its good, its really, really good, when its bad its still pretty good.
  3. 1972Blazer
    Jan 2, 2001
    238
    Next question: My 12 Bolt axel is narrower then my Dana 44 front, is the 14 Bolt any wider?
  4. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    All of the rear axles are like that, you can buy a spacer that evens the rear out with the front. OR you can get a 14b from a van, I believe they are the same width as the front, but a little harder to find.
    As for the converting the 14b to 6 lug. If you are getting a full floater, send a pm to Donovan, he can convert a 14bff from 8 to 6 lug. Hope that helps.
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Donovan on here can convert an 8 lug 14ff to 6 lug.
    A balanced diet is a beer in both hands.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  6. blazingjesse
    blazingjesse 1/2 ton status
    Mar 13, 2001
    159
    kayenta, AZ
    if you can find a 14ff that has disk brakes you don't need the spacer.
  7. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    14 bolts are a bunch wider than 12 bolts
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  8. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    Most 14 bolts are 67" wide and the front axle on a 1/2 tons are 67.5" wide, and 12 bolts are 65.5".
    Donovan
    <a target="_blank" href=http://www.rustbucket.rockcrawler.com>www.rustbucket.rockcrawler.com</a>
    Got Leafs??
