6 Lug 14 Bolt Axel
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 1972Blazer, Oct 17, 2001.
  1. 1972Blazer
    1972Blazer 1/2 ton status
    Jan 2, 2001
    238
    carlsbad, California 92009
    Is there any way to get or convert a 14 Bolt Axel to a 6 Lug Chevy Pattern. I was told a few years back that the 90-93 SS454 Trucks had a 14 Bolt in them and so did some Heavy Half and Z-71's around the same time. Any help would be appreciated.
    1972 Black CST Blazer, 350/415 HP, TH350, NP205, 4" Springs Front/Rear, AGR Variable Ratio Steering, 15X8 Ralley Wheels and 35X12.50 BFG Mud Tires.
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>You can have 8 lug SF shafts filled and re-drilled to 6 lug then get 6 lug drums, or get a 6 lug axle from a Z71. You'll have to move the perches and shock tabs on any SF so you might as well get the one that came 6 lug
  3. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    The CK5 lists own "Donovan" does this conversion for 14-bolt FFs. I talked to him today about this for my own K5....
    Send him a PM and he can give you all the details.
    -Greg72
  4. blazingjesse
    blazingjesse 1/2 ton status
    Mar 13, 2001
    159
    kayenta, AZ
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I was very interested in the same 6 lug 14 bolt custom axle you're talking about. I searched around on the internet and found 2 places that do this...
    I think Drivetrain.com will only weld on new billet ends to the tubes, where i think ORU presses in a whole new axle tube.
    These are 2 emails I got reguarding the 10.5" ring gear 6 lug custom 14 bolt rearend...
    Give Brent a call toll free at 1-800-216-1632. He can review your options and price &amp; design techniques with you.
    http://www.offroadunlimited.com
    Hope this can help.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    A full floater converted to 6 bolt ? Do you really mean the 10.5" FF axle ?
    Then what do you do with the big floater hub ? You cant slip 6 bolt wheel pilot holes over a 3/4 FF hub, it just too big diameter.
    Also, some the 3/4 ton 14 bolt 9.4" semifloaters were 6 lug, btw. most were 8 lug though.
    I never knew about this til a couple months ago.
    '72 K-5 4x4, CST, 3.07, 4 speed, NP 205, 31' x 10.5", Olive green and primer, rusted out, rice smasher!
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Greg is right...someone made it work. Do a search on the main board. The hub and axle flange are machined down and cap head screws used to retain the axles. You have to use aftermarket 6 lug wheels because they have a bigger center hole (to fit toys).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  8. Ryan B.
    Jul 18, 2001
    5,693
    CA
    These places cut off the ends of the tubing or press a whole new axle tube into the 14FF housing, and they convert it to a semi-floating design with the 6 on 6 1/2 lug pattern.
    Its basically the 14bolt 10.5" ring gear center section with custom 33 spline semi floater axles. (Like a 12 bolt with the C-clip eliminator) I believe they use the 1/2 ton drums or you can pay extra for the disk brake setup.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    very interesting indeed, that sounds like alot of work. but why have a big mean pumpkin with reduced hubs and less wheel studs?
    Isnt that a strength issue ?
    Whats wrong with 8 bolt ?
    I have a feeling that I ammissing out on something, here.
    Good to learn new info, however :)
