6 lug 14 bolt ff ?'s
Discussion in 'The Garage' started by bluejeep, Apr 12, 2004.
  1. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    6 lug 14 bolt ff ?\'s
    I've tried searching but the search forum does not like me.
    I've seen pics from somebody on this board of some adapters to convert a 14ff to 6 lug. I am wondering if any machine work is necessary for this mod and if the wheel centers of aftermarket wheels would have to be opened up to clear the hub?
    Just replaced my tow rig with a '99 Suburban 1/2 ton and I don't want to mess around with the 10 bolt rear axle. Considering SAS in the future, but right now I'd like to get it up and running with the stronger rear and retain the Autotrac transfer case....and I'm NOT running different wheels front and back.
    Please don't suggest 14b sf, that's what I had in my old truck. I loved that axle, but this is a new (to me) truck and I'm wanting a new (different) rear axle. Thanks.
  2. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    Re: 6 lug 14 bolt ff ?\'s
    I am looking to do the same thing, the 8 to 6 adapters will work, but the hub of the axle needs to be machined down to fit in the wheel. That's the easiest way I have heard. I'll let you know how mine turns out if I find an axle. /forums/images/graemlins/truck.gif
  3. bluejeep
    Jan 9, 2004
    106
    Des Moines, IA
    Anybody know who that was that sells these wheel adapters/spacers? How much $$$? Pictures? Thanks.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    A guy by the name of Tony P. on here does some of that stuff far as I know.
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Toney P makes them they were a little under $200 and ive been running them for about a year with no problems, the machine work was about $100
  6. bluejeep
    Jan 9, 2004
    106
    Des Moines, IA
    Did you have to machine the center of the wheels? What was the OD you had to turn the hubs down to? Just measured my AR767 wheels last night and the hole appears to be around 4.25"
  7. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    The standard for wheels is 4.250 inches. I turned my hubs and axle drive flanges down to 4.240 and made 1.800 inch thick spacers that are pressed on the hubs so that the wheels would be hub-centric on the axle flanges.
